Discuss Air admittance valve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello, DIY plumber here, I’m after some advice regarding an AAV, my current one goes though the loft and the roof with a vent on, iv seen on some pan connectors have 32mm air admittance valves built on to them. Does this mean I don’t need the 110mm pipe into the loft at all? TIA
Tom
AAV's were invented when it was difficult to vent a fixture to atmosphere.
They were intended for single fixtures like basins, troughs and maybe a shower when the distance from the fixture did not fall within the required length of the vented drain.
As for using them to vent a dwellings entire sewer system was not the intended purpose, hence, I have installed probably 1/2 a dozen of them in 25 years - on single fixtures that don't fall within the ventilation requirements.
I wouldn't disconnect your main sewer vent
Oz is correct you need to vent your drains aav's are not enough especially the smaller size ones they are only a aid to help the flow of waste water from basins , sinks, baths, toilets, ect although tempting to remove pipes and boxings to gain space your asking for trouble theres nothing better than a vent to atmosphere. Kop
Reply to Air admittance valve in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
