Discuss Advice on Sunvic 3 port valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
I'd like to swap my Sunvic 3 port motorised port for a Honeywell.
The issue I have is that the Sunvic has 4 wires and the Honeywell has 5?
Anyone know if this can be done?
Hi the model number is
Sunvic SDMV2304 thanks
[automerge]1569443475[/automerge]
So would I just put the earth wire on the Honeywell into a Earth on the panel?
yes eg where the other earths are (green and yellow sleeving)
Reply to Advice on Sunvic 3 port valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
