Discuss Advice on making this connection.. in the DIY Plumbing Forum area at PlumbersForums.net
Hello....it’s nice living in France...apart from the plumbing...I need to connect to the chopped pipe....the pipe in front will be removed...I think I can solder it...just...any hints or tips ?
I want to avoid concrete bashing...
At a glance, hacksaw blade, file and a compression fitting spring to mind. What does it carry and where is it.
You may need to bash concrete.
Thanks for reply...
Under shower tray...hot water....not sure I can solder as access is tricky..will try compression and push fit and if not enough room solder and if that fails out with the power chisel...I challenge anyone to find anything worse than French plumbing...electrics are worse..
Don't think you'll be doing much with it before opening up the area. Don't let the bits go down the pipe.
Reply to Advice on making this connection.. in the DIY Plumbing Forum area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
