Discuss Advice on enclosed cisterns in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
HI
Does anyone have any recommendations for the most powerful enclosed cistern. I have installed a WC unit with a cistern that has a cable flush cistern. It does flush, but might take 2 flushes to get rid of all the waste and often the water only washes down the front of the WC pan , not all around the pan. I have found that cisterns with a pneumatic system, two tubes that connect to a flush plate are sometimes better. Can anyone recommend a make or model of enclosed cistern which gives a strong flush
Paul
It's not the flushing levers or pneumatics that are the problem with your cistern - it probably the cistern itself.
There are adjustments that can be made to increase the flush volume on the outlet valve.
You may need to do this.
For a fact, I have given up working on them.
I now tell the customer to call the manufacturer for repairs.
Thanks Oz, but have made the adjustments and still no difference
That is a shame. Have you managed to fix it?
Reply to Advice on enclosed cisterns in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
