Discuss Advice on air admittance valve. Toilet in the USA area at PlumbersForums.net
Sorry to be a bit slow and if I've missed the question. Presumably there is a sink associated with each w/c? Could you go for a cabinet style boxed in sink then hide the AAV inside that. Back of the loo could be boxed in also if you wanted. Get it all working nicely first.
The only bee in my bonnet I have about boxing in is the use of veneered chipboard (not good with water) - just my own view.
Cheers,
Roy (amateur)
Cheers,
Roy (amateur)
Small sink in this room however it has its own pipe to the outside.
Vertical normally manufacturer instructions will tell you
There are lots of subtleties to getting wastes right, so I'd recommend getting a good professional in to sort it (The professionals on here have given lots of good advice). Just for interest (if you are interested) try the following video. Note it is USA plumbing standards not UK, but it gives you an idea of some of the issues you can have. Many amateurs think wrongly for wastes that it's just a matter of connecting stuff together. You obviously understand the need for vents of some kind.
A UK plumbing standard version of such video would be interesting.
Cheers,
Roy
Cheers,
Roy
Mines goes to the outside and has an elbow emptying into a gully but not connected to the gully. It is open vented.
Sounds like you want to leave the sink alone then, so the AAV for the WC will have to go at the side of the loo. Perhaps there is some cunning piece of ornamental furniture you could disguise it with? (Get it all working first)
Reply to Advice on air admittance valve. Toilet in the USA area at PlumbersForums.net
In the photo there is a grey 32mm push fit elbow between the sink trap and down pipe. I want to replace the elbow with a "male" push fit tee...
hi, as the title suggests i need help finding this type of toilet seat, i ordered one but completely forgot to check distance between fittings and...
Water nearly rises to top of pan when flushing toilet then very slowly lowers. Tried several attempts to clear any blockages, hasn’t made any...
Hi I want to fit an external air admittance valve to a new stack pipe, see picture. Does anyone have a particular recommendation. Many thanks Paul
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction...
