Discuss Adey Magnaclean filter problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
Intrested1
Hi all,
First post so be gentle!
We run a small pub in Lincolnshire and just been down to the basement to switch the boiler back on after the summer.
The boiler installation is not that old, about 2 years - the installer also fitted a Adey magna clean, it is this that is the concern ( see below )
What would cause the corrosion on the Magna clean ?? - The installer flushed the system and dosed it accordingly , but this is quite concerning.
Is it safe to run the boiler?
Any comments welcomed
Thanks in advance.
Interested1
Looks like the o ring on the top (lid) is letting by, it's nothing to worry about as long as it's not gushing out and you should be safe to use the heating whilst you await a plumber to take a look/repair.
The things is just the deposits that the magnaclean attracts inside. Like above, it will need a clean up and a new "o" ring. It's an easy fix and as its a small leak you can use your heating. But needs sorting soon.
Guys above , advice spot on .
depending on your system , that fillter could be nearly full lol .
IMO great filters .
Cheers Guys for the info - I'll run the boiler until my plumber gets here next week..
Again , many thanks.
Reply to Adey Magnaclean filter problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
