Discuss Absolute headache of a day! airlock or blockage or useless plumber? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
I am very, very confused! this week we have replaced mains from street stopcock to the house entrance. The pipe was severely corroded and split and was seeping through to see it under the floorboards at the front door. Got the pipe connected up ok and all turned on.
It's a bigger than average house. 2 ensuites upstairs, plus another bathroom and downstairs they have a cloakroom.
The problem is the pressure in the cloakroom is very poor at the basin and at the wc. (brand new filling valve and syphon)
In the 2 ensuites upstairs, the pressure and flow are fine on the taps but no water at wc (unless the cloak room downstairs is isolated, i'm getting confused already)
The other ensuite was the same taps ok but nothing at WC, I disconnected filling valve to make sure no blockages, replaced the syphon and now appears to be working ok)
The bathroom on its own is fine at basin, WC and bath.
The cws tank is operating fine.
What would you do if you had to attend this job tomorrow morning? My boss came out and he said we will probably have to stick a hose on the pipework in cloakroom and pump mains pressure water the opposite way round the system and try and clear any blockages.
This job has been laughing at me all day!
U got a monument dry test gauge? 3m of 22 plastic ISo on one end and monument on other via reduicers. Connect to cold at problem appliance. Close ISo pump as high as u can go 3 or 4 bar, open ISo and it's clear!
I don't have a dry test gauge unfortunately.
I assume what you have said is done with the water all drained?
It sort of makes sense but sort of not lol
Na leave water in. Stop tap off and taps open on all floors. Basically ur creating a high pressure plug of air to remove blockage. The 3m of 22mm is a reservoir for the pressure to build up in.
That makes sense thanks.
What if I connected a hose to the kitchen tap and the other end to the cloak room cold tap and, turn on the kitchen tap - would that work the same?
Might cold tap poss 1.5 bar? Bit like a pressure washer and hosepipe comparison, get the job done but much more hard work. How u going to attach to kitchen tap?
If its a downstairs cloakroom, it might be an airlock on the cold pipe as it probably branches off the gravity cold somewhere. If its a mixer tap in basin, cover spout with hand and open hot and cold, may move any air.
If you drained the CWST and your having trouble at the WC's, strip the inlet valves and clear the filters, or if its the old ball valves, check the seatings are clear.
Guess you might have done this today though?
Did everything you suggested while i was there yesterday with no luck. They have water though so that's the main thing, we will be going back next week as i was on other jobs today.
Could be an air lock. How about connecting a length of hose to the water main in the loft, and forcing water through the outlets within the CWS. Make sure the cold tap is open, and don't over pressurise it!
Reply to Absolute headache of a day! airlock or blockage or useless plumber? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
My mother has been away on holiday for a few weeks and she has a kitchen mixer tap that has a very slow drip nothing significant - been like that...
This is doing my head in, so I am turning to the experts here for any wisdom... In the last couple of days I have very low cold water pressure in...
Deleted member 120897
Hello - am hoping someone out there can offer some advice... I've been living in a split level 1st & 2nd floor masionette for two months, which...
4K
