Discuss aav's in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Steve ski
Hi everyone what are peoples thoughts on aav's fitted on the return or negative side of a sealed system? I am currently working on a system installed by another, that is always has a problem with air, I have noted the installer has added aav's on both flow and returns to under floor heating at their highest point in a loft I am looking at them with suspicious eyes. Your thoughts would be most welcome Ladies & Gents ??:1eye:
I don't like them personally and you're better off fitting a brass deaerator anyway.
I don't see anything wrong with Aav's but usually fit manual ones, as above though a deairator might be the best option
Reply to aav's in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Am I right in thinking this is an aav, never seen one looking like this one before but it is on a old megaflo unvented system mk2. The heating...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the...
O
Hi all, Hope you're well. Anyone any ideas... randomly 2 of our toilets started backing up when flushed (2 on same stack 1st floor and ground...
2K
OddJobRob
O
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
1K
