Discuss 4" soil workable falls in the USA area at PlumbersForums.net
Hi All. I am currrently installing a toilet on ground floor. I have cango'ed a channel in concrete floor to back yard and pick up existing waste. I have got a number of different opinions including google regarding fall. It is about a 12 Metre run with no bends. The following falls I was given are: 1" per 4 Ft 1 in 40
and 1" per 4 Metres.
In reality you can get away with lower gradients if you have to. As there are no bends this helps. How far are you going ? and it’s obviously from a standard toilet pan..what happens at the other end..it helps again if there is a drop into the existing. Centralheatking
Thanks guys, that works out at approx 1/4" per foot. Its a 12M run and I will need 1 bend on the sewer side. I might just make it. I think existing soil is low enough. I will have to get the trowel out and build chamber
[automerge]1580501736[/automerge]
15mm a meter I normally work too
Hope im not repeating myself, not used to site yet. Thanks Shaun I was saying thats approx. 1"/ 4Foot. Its a 12M run with bend on sewer side and standard close couple toilet
Reply to 4" soil workable falls in the USA area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
