Discuss 3/8 screwed copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
tom609
This one perhaps ray can answer does anyone know of a solder fitting ie yp or any other manufacturer that fits to 15mm??
Can you now go 3/8 female to 15mm solder/ compression from an existing thread?
or use an expander so you can slip 15mm inside and solder?
or flare it to 15mm flared coupler?
3/8screwed copper is a bigger outside dia than 15mm your thinking or 3/8standard copper which is 12mm
Not in one fitting that I know if you want it soldered. Can do in compression.
You don't make it clear whether you want a male or female end, but the two options I can think of are
15 x 1/4 male iron (what the old timers might call a "3LC") with a 1/4 x 3/8 bush on it.
15 x 1/2 female iron with a 1/2 x 3/8 bush in it.
No ray the outside diameter of screwed copper is 16.5 mm compared to 15mm for regular copper iknow its only 1.5mm but have you tried filing down to get a fitting on someone previous to my visit i guess quite a few yeats back usd a 3/4 x15mm tap connector and solered it in it looked tight and it wasnt that that was leaking ha ha anyway there was 15 mm copper at both ends so added the heavy copper to my:19: scrap bins
Reply to 3/8 screwed copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
