Discuss 2 zone controls with combi in the Plumbing Zone area at PlumbersForums.net
K
Ktm640
Hi all,
We have just had an extension built which will have a new 938 Vaillant combi boiler for CH and hot water.
This will replace a Baxi back boiler in the existing part of the house.
We are installing a new central heating system in the older part of downstairs and throughout the upstairs (the downstairs in the new extension will have underfloor heating).
Building regs state there must be two zones and rads must have TRV's.
Can anyone recommend a good package that includes the zone valves and room stats ?
The ones I've seen all seem to include a cylinder stat that we won't need.
The new boiler will be in a purpose built utility room. Would you normally install the tee to the two zones at the end of the copper coming off the boiler and then install the two zone valves immediately after the tee?
Thanks in advance
I pop to the merchant and ask for 2 of those and 2 of those and 2 of those and it all depends on whether the customer wants to spend more or less as to which make is used, simple really.
How many bathrooms in the house for that combi to be supplying? Have you considered a heat only boiler/system boiler and an unvented cylinder ?
Done deal I think
Considered it but went for a large combo with small in built tank instead
Sounds like you've chosen your system. An unvented cylinder would be the preferred option in my opinion. Your local merchant should be able to help you on the controls side if you choose to go with the 937.
Reply to 2 zone controls with combi in the Plumbing Zone area at PlumbersForums.net
