Discuss Using coil to clear pipe leading to gutter in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Sonya K
Hi, I seemed to have a blockage in kitchen sink. A plumber came and cleared all the pipework that is visible inside my home (there was debris and pebbles!) We saw that the pipe that takes water down the gutter was visibly full to the top. He said he will return with a coil to push through anything that may be blocking it from flowing downwards. He said it SHOULD work but couldn't say for certain.
Can you tell me why; he took away some of the water from the pipe and I went out of the room, i heard him running the water (even though the pipework wasn't connected). On return I saw the pipe was full again. It wasn't connected to my tap which could only mean the water was coming from the opposite direction. The water level looked to be not rising i.e. water wasn't pushing up out of the pipe. Before the plumber came round water was verrrrry slowly draining away from my sink but it was draining. I don't understand why water is sitting in this bit of pipe. Please can someone explain?
And also advise if he is right to use the coil, what the likelihood of success is, and what a typical charge for this is? He is charging £180 - £200 thank you!
Can you post a couple of photos showing the how the pipes / gutters etc. are arranged and point out which section(s) are full of water, please? I'm having difficulty visualising this from your description.
hi! I'll try to upload a picture but the pipe that had water in it was the pipe leading away from the flat to the gutter.
Another plumber came out and turned on tap and after 12 hours I saw water coming up from the sink drain into sink bowl. So water is coming UP, which I dont understand. Then I noticed the downstairs neighbours using their kitchen sink (could hear water running) and then saw water in my sink. Could they be the cause of the blockage? Or is it the drains?
Reply to Using coil to clear pipe leading to gutter in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
My mother has been away on holiday for a few weeks and she has a kitchen mixer tap that has a very slow drip nothing significant - been like that...
Hi all, Bit of advice needed. Waste water pipe from bathroom sink came loose last night caused some water damage to ceiling below. My question...
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors...
For over a week the kitchen sink is leaking water from what I think is called tundish ( I thought is was called overflow but little google search...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
