Discuss 1 pump, 2 showers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MP plumb
hi all,
i would speak to stuart turner but as it is a sunday i am asking for your advice!
I will be installing a gravity fed domestic water with a pump, prob from stuart turner. the client would like to be able to run 2 showers at one time without one getting starved. would anyone suggest a pump that can able this to happen? i know that in normal circumstances, one pump with 2 showers, one would suffer slightly so i want a pump that can manage keeping the flow, temperature and pressure equal when running both.
thanks for your time
Stuart turner will probably tell you to fit the 3bar twin from the monsoon range.
should be piped correctly as per manufacturers instructions.
the tank and cylinder size should be checked for suitability.
Reply to 1 pump, 2 showers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
