Discuss 1/4 turn verses 'washer' tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jennie
Hi all,
My customer is after a new kitchen tap.
She was a bit perturbed that her current 1/4 turn monobloc tap has died - it was quite old, and I didn't rate my chances of finding a replacement cartridge. It was also leaking in two places at the collar on the spout.
How would you all advise her on the pros and cons of 1/4 turn and washer taps?
Thanks for all your advice,
Jennie
I will replace with similar.
especially for the elderly, no need them taking ages screwing down them washered taps
jennie, ceramic disc taps do not like massive mains pressure, the higher the pressure the quicker they will wear out. I always warn customers about this when fitting them. Personally I always go for the screw down type, they last loads longer.
fair point, but for the elderly, I'll always fit 1/4 turns except they say they prefer taps with washers
Bristan used to do a 1/4 turn with rubber washer, but I think they have took it off the market. give lots of problems in this area due to high pressure, and customer thinks you are trying it on when you recommend a PRV.
You can buy decent 1/4 turn taps that will take pressure,in some catalogues it states that they are suitable for high pressure,believe screwfix do
There were quite a few of these around at one point, and most of them were awful. I don't have specific knowledge of the Bristan one, but we tried a couple and then gave up on the whole design.
My recommend for older people who haven't necessarily reached the point where they want "disabled" taps, is a cruciform mixer. cruciform mixer.jpg
Easy to operate, even if the fingers are getting a bit arthiritic.
It's hard to know what is better, - 1/4 turn or standard washer kitchen taps.
Most people wanting a modern fancy kitchen will want 1/4 turn of some type & most elderly people with weak hands will also need & prefer 1/4 turn taps. I personally prefer them to use.
Most importantly try to find out what mixers are reasonable quality & decent flow for the particular water system.
Best to get 1/4 turn taps that you can source the ceramic works when needed.
A decent washer tap does usually last for years.
The most solid solution is proper Pegler 159 HNP taps. More or less bulletproof, and you could probably reseat them every 5 - 10 years for your full 3 score years and ten. without running out of seat depth.
Those are a no nonsense good quality tap & with the old fashioned simple 'screw & packing' works.
I repaired a Peglers pair of pillar taps that are 20 plus years old & it shocked me how new they were, inside & out. Just needed washers.
I hope the Peglers taps are largely still British made? I think some of their modern taps are foreign made. Not all of them are good IMO.
Reply to 1/4 turn verses 'washer' tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
