Discuss Replacing a new boiler but using the same flue hole.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hi guys,
I'll be doing a boiler replacement with a glow worm betcom4 but customer insists I use the same hole..
I've looked at the manual for the terminal positioning and the only way round would be having the terminal extending passed the soffit and guttering with a flue clip. Opposite ge flue there is no buildings or any openings.
Appreciate your thoughts
All good, a baxi and vaillant also allow this. Just needs to be 25mm so as long as it's not touching the soffit or guttering then you are fine
Worcester are ok
And yes Scott baxi dont allow white / flue on show
Might be an old rule but I've just fit one and the instructions said it was allowed to extend past the eaves/carports etc when necessary
Looks like I'm wrong, just checked. I was confusing the 25mm measurement from eaves with the same as vaillants etc. But it does appear you can install the flue 25mm away from eaves so long as no other measurement falls outside the minimum specs.
Reply to Replacing a new boiler but using the same flue hole.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
