If you have a good pressure but poor flow, supply partially blocked, leaking or undersized. What size is the Property??? Is it on Gravity System? Tanks in loft & Cylinder???
There is basement, ground, 1st and loft. Unvented Sealed system. Pipes size i think is OK 28mm mainly. Friendly plumber advise me to boost everything and that's why i look for help and advice
