Discuss Another shocking boiler .... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hi lads I just wanted you to show you what happens when the rubber hoses get clocked up and if you do not use a filter and Ignore boiler services.
Attached are some pics off today’s work which I have taken. Unfortunately I do not know how to upload a video but try to work it out.
Are you working barefooted? :D these days with the widespread knowledge of how beneficial filters Are, there really is no excuse not to fit one. With the boiler packs I buy, for £60 extra you get a magnaclean pro2 or tf1 and a bottle of mc1+ and mc3+. You'd be stupid not to buy it. I was called to a system today with customer complaining of 3 rads upstairs not working, had a combi fitted 14 months ago (ideal logic) all heating piped up in 15mm, took the engineer a day to install, no power flush and no filter fitted. I said no wonder your system isn't working, they was also shocked when I said their warranty won't be valid now and likely has a blockage in her system. All for the sake of an engineer wanting to be in and out in a day. Obviously doesn't care about his reputation.
Was it a blockage?
Was it a blockage?
Didn't have time to look, I was there on a courtesy, my company had fitted the bathroom 2 weeks ago, we used a subby plumber on this one as I was too busy. When filling up after fitting a towel rad he couldn't bleed the 3 bedroom rads as all nipples had rounded. I went round, had to drain down, take rads off to get to the nipples and replace them. When filling back up all rads bled fine, every other rad including towel rail got hot but 3 bedroom rads still stone cold. After turning every other rad off I was still getting nothing so ruled out an airlock. But the customer did say that even before we fitted the bathroom the 3 rads weren't brilliant. I was told by my boss that as it's an existing problem we can't spend any more time on it. I recommended they get the system checked over but was suspecting a blockage on either the flow or return side.
Sometimes it's not in out in a day it's the price the cust wants to pay
No just the customer he couldn’t wait with cracking the rubber which I intended to do after my work but he just grabbed the tubes and did it himself.
Reply to Another shocking boiler .... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not getting through to the boiler. The boiler works fine if I connect the hoses up to a remote tank of diesel. I am assuming that a filter is blocked somewhere but there is nothing between...
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install (tank about 1m lower). 10 days later and boiler either doesn't fire or fires stops, fires runs splutters stops. Most it runs now is 10 mins, but that's...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I can sometimes recover the usual water pressure by turning the hot and cold water taps on and off which seems very strange to me. There is no problem...
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off. I've attached a short video of the sound. It isn't constant, it seems to happen within the first 10 mins of the boiler starting up, then you won't...
Hi, Just had a "Main Eco Compact" combi boiler installed as the Biasi one failed. It seems to work fine, gives a hot bath, i dont ever use the radiators or kitchen hot tap. (no point in upping the landlords gas bill for no reason) On day 4, the pressure is below 1. I filled it back up to >1, but...
