Discuss zone valve leak in the Plumbing Zone area at PlumbersForums.net
sargan
I have a zone valve (220V actuator) on 28mm boiler primary loop ....
and a slight leak from there.
It is not leaking from either of the compression joints ... so must be
coming out via the central ball valve actuator.
It's a Cimberio 1" valve with 28mm compression reducers, model 110.3830 one of these:
http://www.c-o-k.ru/library/catalogs/cimberio/18387/63366.pdf
On page 161 (3rd page in) it shows an O ring & gasket kit ..........
anybody ever serviced one of these valves in-situ
I'm hoping parts will be available.
Never worked on or fitted one, so can't help, but am surprised that valve could leak, unless used a lot. The seals on the ball are ptfe, so same as lever valves
There is a very slight drip from actuator case ... when valve closed. Not dismantled but as not coming from compression fittings assume it's from operating shafts seal (ones in diagram)
The valve operates every time DHW drawn off ... so a lot of use. (Stirs thermal store)
A lot more than a heating zone valve.
Would think it is very straightforward to fit the seal kit, that's if nothing too badly seized.
Hope the seal kit is a lot cheaper than new valve body to justify repair.
Diagram is hard to figure out.
Nothing seized all operating fine.
I have pinged a mail to UK arm of Cimberio, see what they come back with ref kit.
If I have to change whole valve & actuator how expensive are they
Tbh most people won't even change a ballcock washer these days for various reasons.
I've never seen a valve like that but the link gives the sizes of the O rings and an easy to follow strip down repair procedure.
If its for yourself and you have nothing better to do just try to source O rings to suit.
If its for a customer swap the valve because your time and effort won't be appreciated.
Reply to zone valve leak in the Plumbing Zone area at PlumbersForums.net
