Discuss York & Surrey Flange Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gdhaggis
Hi guys. I'd really appreciate some advice on this one.
Basically I have installed a shower pump (all ok) and of course the recommendation is to fit an aeration Flange at the top of the hot water tank. Makes sense.
However - my water tank has a 22mm male input on the top and the couple of S Valves I have tried only have 1" BSP connections/adapters. So - I need advice on a way around this.
I first thought a 1" to 22m simple bush may be available - but I am advised not.
So, now I am thinking : Compression 22mm x 1 BSP Male Straight Coupling, then a 22mm brass socket to connect to the tank. - but can't find a 22mm brass socket, only 1" BSP.
I am a bit stuck now and really need some help. I do not want to change the tank.
Thanks in advance.
Gareth.
Tee down off the horizontal pipe from your tank. Same difference.
Thanks for the reply. An Essex means drilling the tank. Want to avoid that if possible. But may have to go down that route if no alternative. Cheers Chalked.
Hi SimonG
How can I connect the 1" flange female connector if I tee of the horizontal pipework?
Sorry if I am being a bit dim!
GH
As an alternative to a flange you can Tee off the top of your tank, first connection before hot feed Tee for shower feed. For this to work you need to hot feed pipe to run at a angle and connect the shower at 45 degrees to allow the air to go up the open vent pipe and move through top of the pipe (your Tee will be at the bottom so hopefully no air will enter the pump)
first drawing is more accurate
Reply to York & Surrey Flange Problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had a plumber here for 4 hours today to fit a shower pump. He disconnected the hot water outlet from the top of the tank and after 3 adapters for...
First of all I have to confess I am not a plumber so please bear with me! I have a Daryl enclosed shower in an ensuite bathroom. It was already...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
