Discuss Y plan with Vaillant Ecotec plus OV430 in the USA area at PlumbersForums.net
Can Someone tell me how to wire the Vaillant ecotec OV430 with the Y Plan system. Does the orange from terminal 8 junction box go to the RT terminal on the boiler (room thermostat)
Need to be gas safe to be wire direct to the boiler
Reply to Y plan with Vaillant Ecotec plus OV430 in the USA area at PlumbersForums.net
