Discuss WTD - Anyone got 1.5m of 22mm PVC COATED soft copper coil for sale? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andrew2000
Hello,
Colour preference...
White > Blue / Green >> Yellow (latter mandates tape wrapping re colour, altho obviously not gas & no gas available!).
Application...
Replacement of underground pumped drain, long partial swept bends (half-hard not ideal)
Yes I could use plastic... but copper is ideal re rigid form unlike plastic imposing its load on a buried fitting (drain design, unavoidable).
I've got the rigid lengths but not found any soft stuff yet. But got to clear the place out so will keep looking.
Noted, thanks, have to do a lot of clearing out here ... skips ... humdity ... yuck.
What colour is the rigid? Yellow is 2-a-penny anywhere online, but white/blue/green tend to be 6m lengths collect only (some places offer free delivery, but I can't see how they can do that so presume not).
I have an electrical conduit bender which should be better re OD of coated 22mm.
Its the yellow stuff.
Unfortunate... trying to avoid yellow, even tho it is just a click away, because it is defacto gas.
I could use 22 yellow rigid tube, bending spring the slow sweep, street 22 elbow to above floor.
Permanent marker the yellow into black-yellow stripes.
Under floor pipework clipped loose in 25mm ID conduit (to absorb thermal cycling movement).
Above floor pipework clipped tight (to prevent pipe rotation transferring to the pumped waste JG speedfit fitting & flimsy mcalpine spigot).
Not really compliant even as "yellow striped", but it is blindingly obviously a drain.
Reply to WTD - Anyone got 1.5m of 22mm PVC COATED soft copper coil for sale? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Are there any current regs prohibiting the use of 15mm and 22mm soft copper coils for an above ground domestic water supply? I've been given...
5K
