Discuss Working out the weight of lead main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hi, can someone tell me how we worked out the weight of lead per foot by using a piece of string and wrapping it around it? I cannot see it on the search bar any where.
Cheers
Cant remember exactly
As far as..taking a piece of string wrapping around the lead pipe exactly twice
Measure the length of string in cm multiply and devide by something it gives you the LB of lead in weight..
If its to find out what size lead lock you need, just use a universal transition fitting instead, philmac make them, also another brand I forget but they will fit any size in a range, for example 15-21mm
Universal Transition Couplings | Philmac
However most pipes are either 7 or 9lb lead... rarely some are 5lb and some are 8lb....
So I measured with me calipers and it was like 22.68mm OD. So went with 7lb and worked a treat. Philmacs were 45 squids for 2 compared to 16
Wtf why did you pay that much ?
Reply to Working out the weight of lead main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
Morning to any Australians lurking around! Register its free, then message me, I'll sort your account out for you. We will need a moderator from...
PSxxxxxx
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
