R
REDSAW
when fixing boilers and telling the customer that the boiler needs new ignition probe and sensor but they will have to be ordered so you will need to isolate the boiler (as it is part stripped) so it can be finished the next day!!
when you arrive at the job next day to fit the probes and re assemble boiler, you then find it still does not work!!..you can convince the customer that you will soon have it sorted.
after 40 minutes more pass, you then finally spot that you had forgotten to turn on the gas tap back on under the boiler after poking around with the multimeter testing everything, you finally start to re build the boiler then said customer tells you 'i dont know how you did it, i wouldnt have had a clue' you realise how thick some people are, dont you.lol:hand:
