Discuss Worcester grecnstar - changing the plate in the Gas Engineers Forum area at PlumbersForums.net
Jennie
Hi all,
I'm due to change my first plate on a Worcester Greenstar next week (not looking forward to it).
I found this on Youtube. Is it really as easy as this guy says? And what about checking/replacing the O-rings?
Any tips most welcome.
Jennie
Does the pipes go up the back of the boiler ?
Left hand hydro block out and bypass tube you will be fine
Replace the left hand as it gives you all the washers
Worst case you remove the whole hydro assembly eg the two transparent plastic clips, expansion vessel flex out of pump block and guage, slide the prv slider down and undo all the jig nuts and the whole lot will come out
87161072240
We do quite a lot of work on these and I always find it easier to just drain and remove the whole hydraulic flow and return sections in one. If it's over 7/8 years I always advise customer to replace plastic flow block, dhw restrictor and prv, cost ÂŁ60 ish but massive saving in the future. Just take your time undoing everything and cover board etc with a towel.
Or a Cdi 20 mins and a left hand hydro block :D
Reply to Worcester grecnstar - changing the plate in the Gas Engineers Forum area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
