Discuss Worcester danesmoor 20/25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stani
Subscribed
Anybody got a copy of the Mis for this 20/25 possibly a 1989 version, just need the baffle positions the Worcester site show all different models but not with these baffles, like a four sided tray, also need the info on Electro burner. ImageUploadedByTapatalk1363965594.235726.jpg
Cheers Stani.
Don't know wether this is a better pictureImageUploadedByTapatalk1363965728.385172.jpg
This is an extremely old worcester. I still look after a few of them and i can try and find you some info on baffle arrangement. Is the burner ok?
Is this the one that the 4 baffles fit around the inside of the combustion chamber and then two square baffles slot inside them
Yes it's an electro still! Working but bad weather made the baffles displace, was just trying to get them into correct place.
They are more like square trays with around 25 mm edges they appear to sit at an angle on top of each other.
This one, top right corner, it's on the Worcester site
I looked at that but didn't think it was the right picture for the baffles, perhaps it's more like the left hand top, but thanks anyway.
I have put a report in to explain the limited availability of spares. And suggested a new condenser, money spent on servicing, parts location, just generally trying to keep it going all adds up to a replacement.
I can give you anything you need to know about the burner. Is it an Inter 10 or 11?
An 11 I believe, have you got any info? Anything would help, got he nozzle size off the data plate but there is nothing else.
cheers stani
Stani, does this mean you made the schoolboy error of not noting their positions while taking them out lol? I've done that. Or do you think they were put back in wrongly?
Just had a thought, that's not the one where they all hang around the edge of the chamber is it? I'm having vague recollections. Or if its just one like a 4 sided tray, your not talking about the target plate that hangs off the back for the burner to fire on?
Inter 11 normally 140psi 4mm spark gap, 10mm from electrodes to centreline, PL1 or PL10/4 blast tube, 40-42mm from nozzle tip to end of blast tube.
No, unusually not, the reason I went was firing for 5 minutes and then lock out, the trays were all in the bottom of the chamber due to severe winds, which had disturbed them, hopefully it's going to be a new boiler, fingers crossed. I have put the, back at angles as most Mis show and it fires and works, 0-1 on smoke but had forgotten to put Fga in van as it was a call out . Just needed clarification to put my mind at ease that they were in the right place.
Not the target plate but definitely the baffles which are set like alternating steps, 1 angled to front, then the next angled to the rear etc.
Just tried thanking myself, been a long day.lol
Reply to Worcester danesmoor 20/25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
  • Locked
hi all, I know this is a long shot but I'm wondering if there are any M&E contractors who specialise in plumbing that can help me. I think my...
11K
  • Locked
Hi chaps. I’d like to change the bearings in the burner motor of my Worcester Heatslave 20/25, and I’m just looking for a few helpful hints...
6K
Bunker
B
C
  • Locked
Hi, I've got a 10yr old Worcester Bosch Heatslave 20/25 oil boiler & by the sound of it the bearings are on the way out on the burner. It's an...
13K
CraigT
C
C
  • Locked
Hi. I've got a Worcester Bosch Heatslave 20/25 oil fired boiler and the burner has stopped igniting. I have done a fair amount of fault finding...
17K
  • Locked
The diverter valve on my Worcester 20/25 stuck down a few months ago resulting in my radiators getting red hot even when the stat was not calling...
4K
