Discuss worcester cdi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stokecity
Hi guys
worcester cdi is giving out lukewarm water, measured at 33 degrees at all outlets. Heating is working fine. Taps are working fine. Diverter valve is operating. The ho****er outlet pipe at boiler is hot to touch. I dont think plate is blocked as temp doesnt rise high and the burner doesnt cut out. Fan runs at low rate and never runs high rate even from cold start.
Ive ordered flow turbine.
Is there anything else it could be?
Cheers
If you go into service mode on CDi's they can display HW flow rate. Would tell you what the turbine was reading
If it fires up then the turbine is fine... I would go hw sensor too
Reply to worcester cdi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
