Discuss Worcester Bosch Flue Installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chrisamyphillip
I have recently moved into a property that had a new oil fired boiler installed approximately 2.5 years ago.
The boiler is in the attached garage and the flue goes through the garage roof, 3.5 inches parallel to the cottage wall. The flue has a 90 degree outlet (termination ?) at the end of the upright section. My issue/concern is that the room adjacent to the flue is suffering from condensation on the walls on the 'other side to the flue'.
The flue height does not exceed the roof tile line and the 90 degree outlet although faces away from the cottage wall, its' final exit is approx 14 inches away from the cottage wall. Obviously facing away.
I think that the flue gases are blowing back towards the cottage wall and the hot/warm gases are hitting the cold cottage walls, condensing and causing the condensation internally.
Thoughts / ideas?
vert flues shouldnt have 90 degree changes of direction on them at the terminal end, in my opinion, the flue should have used 45s from the upright off the boiler to take it away from the wall before exitng vertically. as said call in an oftec technician for an opinion and resolution
No they arnt causing condensation internally they would actually reduce it as it would heat the wall and prevent condensation from forming. It's hot humid air internally rising and meeting with cold walls. That's why it's high and on outside
I completely agree with both above points. LP is right, ideally it should have been done differently but as Ermin says, unlikely to cause your problems as the flue temp at that height could be perhaps only 50 degrees which will run off your brickwork rather than heat it or soak through.
Id be looking at your tiles and or guttering or where the 2 roofs meet.
It depends how high it is, it could be a high level horizontal exit termination. Check the manual for maximum distances.
Reply to Worcester Bosch Flue Installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Oily smell from boiler recently before failed. Great plumber sorted though when opened external baffle at front of sealed flue the internal spring like tube lining outer insulation had all perished. Barn conversion with thick walls (763mm). Worcester Bosch say Flue Kits are obsolete and...
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the flue bend. I’ve checked the external wall & there’s no water coming in from outside but the flue terminal also has a rusty colour. My regular boiler...
1K
J
We’re thinking of replacing our veritable Ideal Mexico Floor Standing Boiler (installed by me in 1985 and pretty much reliable ever since!) with a Worcester Bosch Greenstar 30CDi boiler. Question: How noisy is it? We’re OK with the noise from our old boiler but we’re worried about any...
Hello Everyone Recently bereaved friend of mine is wanting to replace his 15 year old Combi. It is in the loft on the party wall of a semi ( pitched roof has three sloping sides). He asked his Gas Safe Service Engineer for a price to replace. Engineer said that existing vertical flue is too...
1K
Deleted member 120897
J
Hi - I'm not sure if this is the right forum or not, but I'm looking for some advice with regards to a recent (nightmare) new gas boiler install. Our old gas combi boiler needed replacing, so we shopped around and got a deal via BOXT. Our understanding is that BOXT then sub-contract to local...
4K
Mark Butler
M
