Discuss worcester bosch accredited installer course in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Guildfordboiler
Hi
Can anyone tell me what it is i will be doing and what they will test me on so i can study to freshen up a bit done my acs 4 years ago!! all I know its a assessment course run by logic so I can become a accredited installer
First they connect you to a intravenous drip and drain your blood whilst refilling it with a lesser diluted plastic resin that will surly fail in due course.
then they take you into a darkened room and play music with subliminal messages in this is known as the brain dulling process once complete they take you to a bright room and tell you to thank worst er for that
once complete your good to go and no one will ever be able to convince you that they are over priced tat.
think Stan has already been on it I got worried they the other day it looked like they had also gotten to ermintrude
I decided to become a registered Worcester installer because they are a well known brand now as they have advertised really well
I used to fit vaillant but had a few that needed diverters changing after the 2 year warranty ran out
Pm gasman you gs details so you can access the gas forums
me too but don't forget also vaillants poor customer service and the boilers rubber hoses, pressure sensor, pump, primary heat ex, pcb's dhw heat ex rubbers but gas valves were ok
Yes the customer service is top notch every time I ever call Worcester I am talking to a person within a minute max try getting through to baxi!! 35 mins last week
well done it and am now a W.B accredited installer
they just went through loads of info on there boilers and had to sit a exam on heating systems and pipe sizing etc
Reply to worcester bosch accredited installer course in the Plumbing Jobs | The Job-board area at PlumbersForums.net
