Discuss Worcester 27 RI wiring problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Philipo2004
Hi everyone
Just removed a glowworm 330 and installed a worcester 27 RI. The original wiring came from the junction box and was connected to the glowworm as follows: mains live, switch live, neutral, earth and a pump live. There is a mechanical thermostat and a Drayton digital programmer which goes to the junction box also. To connect the worcester it has to have the mains fused spare 3 amp direct to the boiler. Can I just disregard the original wiring to the glowworm and run a live, neutral, earth from the worcester to the pump?
would I also disconnect the pumps original wires which also connect to the original junction box? It's a Y plan system. Thanks
Reply to Worcester 27 RI wiring problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
