Discuss worcester 24cdi no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
adp
To get hot water I have to turn on the central heating as well. Once the central heating changed to position '0' the hot water will stop soon.
With central heating running in the mean time the hot water become very hot. However if I get cold water running in the kitchen mix tap to drop the water temperature, there is no hot water again.
can anyone give me some clue? The boiler is an old worcester 24cdi RSF.
Unfortunately Ollieg is right. In the interest of gas safety nobody will advise you to open up your boiler yourself. Should you be a gas safe registered installer I am sure Croppie will guide you the right way.
Thanks lads.
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a private message to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to worcester 24cdi no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My first thought when I heard this fault a combi boiler with hot water but no heating. Was a problem with the stat, controls not making the call for heat. If this is not the case. Can the divertor valve be the cause of the issue?
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to give a full picture but let me know if ive missed anything. I have a Baxi Avanta 25h heat only boiler. Works fine. Unvented 300ltr megaflow. Stated...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
When I put the central heating on the hot water gets drawn through the pump but is then being diverted straight back to the boiler instead of the rads What is this, and how likely is it that it is faulty? That sits in between the hot water to the rads and hot water to the hot water tank...
