Discuss Woodburner connecting to an existing back boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Louise Wray
Hi there... I have just bought a lovely wood stove from the 1930's, (France or Belgium), it's totally reconditioned and ready to go, but I know nothing else about it!
We have an open fire with a back boiler and would like to replace it with the stove, but if possible, keep the back boiler, as we find it useful, not to heat the whole house, but more to top up hot water.
My plumber has not had much to do with fitting woodstoves, so couldn't really help. We will of course use a professional but just need to know at this point if it's actually possible?!
Many Thanks in advance for your help.. but please keep the technical jargon at a minimum, I'm a Yoga teacher, not a plumber!!
Louise
You can't use the back boiler from the open fire but if the stove has an integral boiler then it's possible to connect to existing system.
Totally agree old back boiler must
Come out
HI Louise, do you mean Franco-Belge, These boilers are still available. You need to find out what the potential output of the boiler is. Too large a boiler with too small a heating load will mean the thing will just tarr up your flue. Your open fire will may just do hot water. However, if it has radiators as well it will be a high output boiler. Your plumber will determine the difference. You can also get help from HETAS who are similar to the organisation for gas (GAS SAFE or formally Corgi).
HETAS only deal with Solid fuel units. Look their site up on the internet. Google HETAS. Solid fuel stoves should only be fitted by a HETAS registered plumber/htg eng.
PS you may need toohave your chimney relined for the stove to work at its best.
Good Luck , Plumbo2
an appliance using one form of fuel(wood) can not share the same flue if another appliance using different form of fuel(Natural gas).
hello and welcome, may be better posting this somewhere else on the forum?
Reply to Woodburner connecting to an existing back boiler? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
