Discuss Wood Burner back boiler with gravity rad system. in the The Welcome Wagon :) area at PlumbersForums.net
Hi All...thx for the help in advance.
I have recently installed a wood burner with back boiler heating system. Set up with gravity rad and header tank in loft.
I have a recirculation pump installed that I have connected to the rad system that I turn on and off manually.
I wanted to know how and what i need to install a thermocouple attached to the copper pipe that activates the pump when it gets to the set temperature and turns it off when it goes below this.
How does it connect to the pump, what do I need to have for this to work.
Many thanks Brian
Reply to Wood Burner back boiler with gravity rad system. in the The Welcome Wagon :) area at PlumbersForums.net
Hello everyone, I'm facing a rather complex situation and I need your expert advice. My neighbor and I share a boiler for hot water, and we have...
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to...
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
When I put the central heating on the hot water gets drawn through the pump but is then being diverted straight back to the boiler instead of the...
