Discuss Wirsbo Under floor heating system, downstairs totally cold :( in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My system is split into upstairs and downstairs. The upstairs is working fine
but the downstairs is off.
There is no hot water in any of the pipes in the downstairs system, the pump
is on/warm and there are gurgling noises, but all pipes are cold even under the tap (like a radiator tap)
Any suggestions please?
Sounds like you have air in the system
Did it just stop working or did you have some work done on ANY part of the heating and / or controls?
Any chance of a pic of the ground floor manifold ?
Right that's great do you have a sealed system (eg filling loop) or an open vented system
3:50 onwards
Many thanks.
Im not sure which system it is but I will look into it.
The video is great I will check the set up and see if I can tackle it myself.
Reply to Wirsbo Under floor heating system, downstairs totally cold :( in the Plumbing Jobs | The Job-board area at PlumbersForums.net
