Discuss Wireless thermostat compatability? brands? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
I have a Grant oil boiler about 5 years old, controlled by a Honeywell st9400c programmer and all is well with it. My problem is that the analogue thermostat is in it's traditional hallway location and I want to replace it with a newfangled wireless version so the thermostat can be wherever the new baby is - as she's a bit more sensitive to cold than we are. There are 4 wires through the wall to the thermostat, earth, neutral, live and I guess a switched live(?)
Question is, as I just need the wireless base to go where the analogue is and turn heating on/off, are there compatibility problems? I see a lot of cheap Salus units about -will these do the job or do I need something more expensive - the system's not zoned and I dont need control when I'm out.
Thanks in advance,
Reply to Wireless thermostat compatability? brands? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
Hi I'm having issues with my wireless Honeywell thermostat. It's sat in the living room, set at 18C currently. It makes my Worcester Greenstar 18Ri to short cycle. So, the moment it gets cold outside my boiler works for about a minute, then stops, and starts again in about 5 minutes, then...
2K
Hi, Does anyone know what product is a good replacement for a Honeywell CM927 wireless thermostat controller and BDR91 Relay Box that controls my electric underfloor heating? I assume it needs to be another Honeywell product and the T4 wireless thermostat but I haven’t found any guidance on...
1K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Morning, I have a job later this week with the above , Viessmann Vitodens System boiler. It has a 4 pipe setup with internal diverter and at present there is a wireless thermostat/programmer controller in the hallway. Customer wants a Honeywell Evohome System and I just wondered if I can wire...
