Discuss Wireless stat problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Any thoughts guys.
Called out to a Siemens wireless stat this morning where signal is not reaching boiler.
Boiler is a Biasi SpA if that has any bearing.
Checked all wiring and that receiver and stat have power - both ok. Is this likely to be a boiler problem or a stat problem as I think I've checked and tested all switches and connections that I can think of.
Ps boiler fires fine using manual controls as previous engineer had bypassed stat to allow CH usage.
Any thoughts appreciated
I'd say receiver fault! Is it the one with the big wheel in the middle? If the stat has been linked out no fault with the boiler IMHO
Yes it is the one with the wheel. I had a feeling it'd be the receiver too but ran out of tests to try. Cheers
Have you tried resetting the receiver remove the battery and reconfiguring the link between the 2 I always try that first before doing any thing else
Siemens ones need re-linking when the batteries are low. On the back of the stat unit, there should be a couple of buttons behind a cover. Can't remember the sequence, but you have to do something with them to re-link it.
Reply to Wireless stat problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW...
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed...
2K
Following on from my question about monitoring F & R temperatures, I needed a measuring device because the overheat stat. frequently trips and...
1K
Hi all,new to the forum and hoping to get some guidance through the boiler minefield . We moved into a 70s bungalow last Feb,its got a Greensted...
So I've used a wireless thermostat to activate my heating since installation, but it's just stopped working (Blank screen, no new battery's fixed...
2K
