Discuss Will my £30 McAlistair tile cutter cut 10mm porcelain tiles? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
HI everyone. As per the title, can anyone advise whether snap tile cutters work on porcelain tiles or do I need a wet saw? Thanks
Depends on several things grade of porcelain tile what cuts you want to do small strips or intricate better with wet cutter.
Decent porcelain snap cutter eg rubi probably more money than you want to spend.
Do a test but if grade 4 and above I suspect maybe not
Reply to Will my £30 McAlistair tile cutter cut 10mm porcelain tiles? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
