Discuss Wickford, Essex. Advice needed don't want to be ripped off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, need a little advise. Guessing I need a heating engineer to check my unvented megaflow system. Getting heating no problem but no hot water. My thoughts are its either the moterized valve or thermostat causing the issue.
last guy I had round for an issue last year swapped parts like no tomorrow before finding the issue and don't want this situation again. Turned out to be the boiler fan, but swapped, Pcb, moterized valve and something else.
also the pressure of the system keeps dropping slowly, but have not found a leak anywhere.
any recommendations in my area?
thanks
You are quite right as stated in your previous now closed post you will need to seek the professional services of a G3 certified heating engineer. You are right in thinking that the controls you referred to are likely causing your hot water issue. These are unrelated to the dropping pressure which could be attributed to a number of things but is typically due to one which will be readily identified by a good heating engineer. I sadly am not in your locality or I would have happily offered to carry out the necessary repairs. Hopefully some one on here will be local enough to assist you. Alternatively ask friends, family, neighbours and colleagues if they know of a good heating engineer. Could also try popping to some trade plumbing retailers and asking for contact details of a good engineer. Diy sheds like b&q dont count. If you have a good independent plumbing trade retailer then even better, they should be able to point you in the right direction to get a decent reputable, appropriately registered and certified plumber/ heating engineer.
I have PM'd you the name of an engineer local to you who knows what he is doing.
Reply to Wickford, Essex. Advice needed don't want to be ripped off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
