Discuss Why arent these more widely fitted in UK ? Unvented wall mounted water boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
100l direct cylinder but normally 30l under sink water heater for commercial uses
Rianni make a similar one. I've used them in flats, when they have electric heating.
had one supplied and fitted, 30lt ariston by a spanish 'plumber' (in spain)
60euro's ALL IN that includes carting it up the street 400 yards and to 4th floor.lol
Reply to Why arent these more widely fitted in UK ? Unvented wall mounted water boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but I'd like to do it myself if possible. All images for system here: https://*********/a/ngPQkre Last winter the temperature switch on my boiler...
Butchy10
B
Hi all, My customer needs a new water heater/boiler - preferably electric. (Getting the gas pipe through to the desired location is a bit of a no-go. It's a tiny stone-walled, screed floored terraced cottage, with no easy route for the gas pipe. So we're looking at electric options). Two people...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up blowing/melting a hole in one of the pipes. I repaired this by putting in a new stretch of pipe in and just connecting it to the existing pipes with two...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by the survey. I have had loads of plumbers over, and have always carefully checked their reviews/tried to vet them as much as possible. However, I've had...
