Discuss Which Motorised Valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Affick
We have old Drayton (fused unit) motorised valves regulating CH and HW which need to be replaced. These are regulated by thermostats and power the boiler and pump. I want to use the Honeywell V4043 valve. However, I note that these have 'A Potential Free End Switch' to power the boiler and pump. What exactly does that mean? Does it mean that these valves (which I have bought) are not suitable for this purpose and that I should have bought the V4043H?
Many thanks for any help.
Affick
How is the old Drayton wired ? how many wires does it have & can you see there colours ? I take it that they are two ports ?
Thanks for your reply. The old Drayton Lifestyle valves are 5 wire but I havent looked at the colours. (Its like a spaghetti junction in there). THe V4043 is also 5 wire.THere are 3 valves, all 2 port (up/downstairs and HW).
Are old Draytons spring return type (is there a lever on the side that can be used to open them, if you are not sure you can post a photo or get somebody in, if you are not confident with wiring these back up you can get in to all sorts of trouble.
Reply to Which Motorised Valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
