Discuss Which drill? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wetdrip
Hi guys, hope all you tarts are keeping well:)
Day one of my holiday, and I'm trying to fix my greenhouse base into a concrete/ballast base.
Marmalised two masonary drills sofar.
WHICH DRILL WILL GET THROUGH THIS PIGGING MIX?
Sds goes through like butter, but that means you need a new drill unless you have one
or stnd Bosch bits are good
As above, ^^ and sds drill bits seem to last nearly forever.
I only ever use ordinary round shaft end standard masonry bits for fairly soft or tiled walls nowadays and using a battery combi drill. Gone are the days of constantly buying masonry bits to replace worn out bits.
Reply to Which drill? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the shower drain is actually extruded from the bottom of the shower base and I have concrete floor with the drain pipe rough in. I have the drain pipe...
I have a hot water slab leak which is found behind my bathroom vanity. We heard the noise for a week but never saw any water. Just today we saw water starting to come up under the vanity. I found the leak, my question is is it ok to run the hot water just long enough to take a shower? Does it...
drpepper68
hi all i need some help and advice i am tiling around 2 shower pipe fittings. as the measurements were intricate i was practicing on off cuts and trying to create a template. I've noticed when i drill holes into the tiles sometimes they would crack. i don't use any pressure or drill too fast...
1K
Hi, guys! Hope you are all well. I have four solenoid valves connected to the main water supply, and they seem to break quite often. I believe it's the pressure that's causing this. I was thinking of adding a pressure valve to control the pressure before it goes through the solenoid valve. Do...
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's still hot there so I'm guessing there's a problem with cold water feeding into the hot water somewhere along the line. I have mixer taps on two...
