Smurf
Now that I've got my central heating system working properly (see thread '2 cold rads') should I run some cleaner through the system and if so should I use Fernox F3 or Sentinel X400?
Discuss Which central heating cleaner? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
X800 is decent although it foams a lot and can be a pain to get back out of the system, and if you dont it will literally eat your heat exchanger (had it a few times before speaking to the rep who said you can only leave it in for up to 4 hours without it doing that). F3 from Fernox is good stuff if you can leave it in for a few days, no issues (touch wood) with leaving it in for longer either but you need to remember to get the sludge out too so try dynamic flushing with the filling loop open and a drain cock open at the other end of the system
Thanks for the comments.
Gas man, just out of interest what part of south Wales are you in?
Reply to Which central heating cleaner? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
