Discuss Where should the soil pipe enter through the slab? in the USA area at PlumbersForums.net
I'm building a new house and want to know is there a standard location\ distance from walls that the soil pipe should come up. The pipe will take a WC on the GF and then stack up to the 1st floor to take the bathroom above and then up to vent tile so he'll need a couple of T connectors which usually have a boss adaptor on 3 sides. I'd like the boxing to be as narrow as possible but without snookering the plumber on his first fix and they can't be adjusted afterwards due to a gas membrance secured around the pipe before the pour of the floor.
I've attached a GF plan and the SVP's are shown.
Thanks in advance
  • Plots 1-3, Greenwood Tree_GFCOM_P2.pdf
You need to think what your having on the walls eg tiles plasterboard etc
normally a clip off the wall
Yes I normally allow 105mm to the centre off finished wall eg tiles plaster etc
Reply to Where should the soil pipe enter through the slab? in the USA area at PlumbersForums.net
Sonya K
