Discuss When can the washing machine be used? in the USA area at PlumbersForums.net
Can a washing machine be used at the same time as the wc flush, running a bath or watering the garden?
Depends on your incoming water pressure and flow if it’s low then no I wouldn’t use anything when the washing machine is on it’s full cycle
In a normal house on mains water supply the answer should yes. Why are you asking?
Because my Wife is concerned that if the Loo is flushed when the Washing Machine is on or filling, the WC will *rob the Washing Machine, thus throwing it out of kilter in some way.
Our Water Pressure is completely normal, it is just that my wife feels if the loo is flushed or the bath is run at the same time as the Washing Machine is filling or running, the other appliances will *rob the Washing Machine and it will not work properly.
If I run my kitchen tap fast at the same time the (Bosch) washing machine is filling it flashes a 'low supply pressure' error code when when the programme finishes. Doesn't seem to cause any problems beyond taking a bit longer to fill.
Reply to When can the washing machine be used? in the USA area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
