Discuss Whats is the rules regarding the below now in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
I was in the process of removing a back boiler fire for a combi , the cust did orignally go with an electric fire where the back boiler fire once was. Today they changed their mind and want the old fire left and working. Obviously the bbu is going to be decommissioned but didng the regs change on leaving a working fire in this scenario ??
Or am i wrong
Baxi did a tb on this phone back up and get them to email it you across
I went through this last year , rang Baxi , rang GS , both said you could, but , er if it goes **** up it your fault. I wouldn’t refit the fire in the end .
I would decommission the Boiler (drained and disconnected from Gas and electricity and Labelled as such), Leave fire working.
What difference does it make. When the whole thing is working there's no law that says you MUST use the Boiler. You could also Block the ventilation for it provided it falls within all relevant criteria for gas fires and is safe.
Reply to Whats is the rules regarding the below now in the Plumbing Jobs | The Job-board area at PlumbersForums.net
