Discuss What would do to replace a broken p shaped bath panel? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
I see they can be purchased but surely the p shape part will vary and getting something close enough would be tricky? Not been asked until today.
Nope, it's shot in the dark you will be very lucky if you get it right first time
Best option is to get it repaired by a local body shop if your not very good at doing fibreglass
You also could make a bathpnel and tile the front with some access panel for the future. Perhaps magnetic opening would be good.
Really need to get the manufacturers panel. Different radius etc.
Or find a boat builder. Nice glass fibre repair.
Reactions: rpm
If you know make of bath should be able to get a replacement that is of course if its not from one of the sheds then no chance, find a good chippi / kitchen fitter who could build one.
Reply to What would do to replace a broken p shaped bath panel? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
