Discuss What size pipe is needed to make a complete flush pipe for a high level toilet cister in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
laptop
I installed a high level cistern and need to make a flush pipe so i went and bought a flush pipe, 36x1.8 solvent weld pipe, internal rubber flush cone, 36mm bends & straight connectors but i have come across a problem where the straight connector won't fit over the flush pipe so as i don't want to use a compression fitting between the flush pipe and pvc pipe i was wondering is there a solvent weld fitting i can get to join the two pipes together. I did think of making a complete flush pipe with the pipe i bought but then it's to loose in the flush cone so i'm guesssing it would leak so would anyone know what size pipe would be best to use if i decide to make a complete flush pipe.
Re: What size pipe is needed to make a complete flush pipe for a high level toilet ci
You can buy high level flush pipes complete either 2 or 3 pieces depending where your cistern is located if it is above the pan as you stand in front of it you will need a 2 piece if it is to the left or right of you as you stand in front of the pan you will require a 3 piece and you do not require any bends or couplings or solvent cement all available at any good merchants hope this helps :)regards turnpin
Reply to What size pipe is needed to make a complete flush pipe for a high level toilet cister in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
