Discuss What size is the nut holding the outlet onto the back of a urinal in the USA area at PlumbersForums.net
Hi all,
I need to take a urinal off a panel to fit some plastic covering to the panel. Can someone tell me what size might be the nut holding the water outlet onto the urinal. It is an ideal standard.
1” nut if it’s the one onto the flush from the flush pipes to the cistern
Or do you have concealed ? Then it’s normally 1/2”
Picture might help
It's the thin nut on the back of the chrome spout that I need to remove. It is recessed in the panel. I need a box spanner to undo it so that I can lift the urinal off it's brackets.
16336040402083851288163505097328-jpg.64307
Reply to What size is the nut holding the outlet onto the back of a urinal in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
