  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss What Part Do We Need ? in the Sanitary Ware area at UKPlumbersForums.co.uk.
  1. dhayden1968
    dhayden1968 New Member
    We moved into a new house a few months ago. The previous owners left us a note saying the toilet need a new part and that they had ordered it. The toilet still flushed but had to be done by sticking pen in a plastic unit that was sticking out of top of the toilet.
    The part never turned up and we are finally sick and tired of fiddling with a pen every time we want to flush the toilet.
    Trouble is I have no idea what part we need.
    Can anyone give me any pointers as to the part, where we can get it and how easy it will be to install..
    Thanks.
    David
  2. rpm
    rpm Trusted Plumber Top Contributor!!
    Welcome to the forum, it will be a cable button, is there are brand name on the cistern lid or the toilet pan anywhere? It`s not one I recognise but maybe somebody will be along later to help.
    This is a link and they say send us a photo if you can`t find a name.
    Toilet branded push buttons for WC's
    • Like Like x 1
  3. dhayden1968
    Thanks RPM - cannot see a brand name anywhere. Will try sending toiletspares the pics.
    Cheers
    David
  4. rpm
    One of the other guys might be able to help when they get home later.
  5. ShaunCorbs
    ShaunCorbs Trusted Plumber GSR Top Contributor!!
    Looks like a stnd push button
    Your best bet is to go to a local plumbing suppliers and take your existing flush with you (should quarter turn and come out) you will have to buy the whole siphon but it should fit
    Hope this makes sense if not please reply
    • Like Like x 1
  6. ShaunCorbs
    • Like Like x 1
  7. dhayden1968
    Thanks.
    ToiletSpares have already replied and identified the part I need
    "Replacement dual flush button for the Derwent Macdee DVA100 Kayla flush valve with yellow cable. "
    Hopefully this will fix our problem
    Regards
    David
  8. ShaunCorbs
    For the price of it I think the best option is go for the complete kit least you will have a spare flush mech
    https://www.toiletspareparts.com/index.php/toilet-spares-by-type/push-button-cistern-spare-parts/toilet-flush-valve-and-button-packs/derwent-macdee-kayla-cable-operated-dual-flush-valve-afv50100-afv50200-dva0100.html
    • Like Like x 1
  9. dhayden1968
    Ah, hadn't thought of that. Is that a standard fitting ? and would it just be a case of unscrewing old one and screwing in new one.
  10. ShaunCorbs
    If it's the same as the one you have just pop the mech out 1/4 turn and slide the new one in and 1/4 back and job done
    • Like Like x 1
  11. Paulplumb
    Paulplumb Plumber GSR
    • Like Like x 1
Loading...
Similar Threads - Part Need Forum Date
I will need a help to chase a part Plumbers Arms Apr 28, 2017
Part needed - please help! Central Heating Forum Nov 18, 2016
Help needed taking a tap apart Valves & Taps May 6, 2016
Detached Exit Pipe - Need new part? Plumbing Forum Jan 23, 2016
How desperate have you been for a basic part on a job and what have you done to get round it? Plumbers Arms Jun 25, 2017
Fordham shower door spare parts New Member Introductions Jun 20, 2017
Replace thermostatic mixer shower where surface pipes are only 3.5cm apart Plumbing Forum May 5, 2017
