Discuss What kind of pump can empty a full septic tank in a remote area? in the USA area at PlumbersForums.net
I thought I could buy an external pump to pull out with a two inch pipe and send it away from the house.
In the UK, the rules governing discharges from septic tanks, etc. were tightened in 2015 with a final deadline for compliance sometime (Jan IIRC) 2020. I recommend that you get a qualified company to review the current arrangements and advise. There are potentially huge fines and costs associated with unlawful discharge of sewage; septic tank outflows no longer qualify for direct discharge into water courses, etc.
It's now quite a complicated set of regulations so DIY modifications are very high risk.
Reply to What kind of pump can empty a full septic tank in a remote area? in the USA area at PlumbersForums.net
I found a concrete slab buried in my back yard where the drain field is supposed to be. It appears to be "L" shaped 22.5' X 21.5' on the long...
Stuck-in-the-Muck
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
R
Hi all, I have a submerged pump in my drain (a Hippo 50) pumping uphill on my property to the sewage main. I've been noticing a bit of a sewage...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
