Discuss What is this? Why are there two pipes on this radiator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
twopipes
Hi, was wondering if anyone could tell me why there are two pipes here on my radiator in the picture, and how I can remove this type of twopipes.jpg radiator from the wall? The other side has one standard pipe. Please help :( Thanks.
Hi, I'm not sure, I htink so :-S I have just never seen a radiator with two separate pipes going from the vertical pipe into the radiator itself...
There are twin pipe rad valves but as far as I can tell from your photo that is not one of them. Is it possible to have another picture from the side as well as the top ?
Hi thanks for your replies. Sorry I don't have a better photo right now, I'll try to get one and post it.
just top add, there are two horizontal pipes (not sure if this is what they are called in the trade?) coming out of the single vertical pipe and going into the radiator.
Looks like a single pipe with a 15X15X1/2" tee with a Draw off cock screwed in, for draining the system.
I would be more worried about the big green thing:50:
does it make a noise when you touch it !!!
That's all I see too.
A pic with both ends of the rad in shot might be a good idea if that's not the answer you're after.
Looks like a normal rad with drain point fitted below valve, you just remove rad the same way as any other.
Reply to What is this? Why are there two pipes on this radiator? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that has previously been extended. In one of the bedrooms that has been extended there are 2 radiators, one which looks like it was fitted when the...
Hi, I’m looking for some advice on how to remove this radiator value to check if the pin is stuck. I have two similar values in the house where those radiators aren’t heating up at all. The pipe leading into the value is cold but the rest of the system is working fine. Thanks for any help/advice!
Hi I have a leaking TRV on a downstairs radiator and need to get it replaced/fixed. Can anyone on here tell me the average cost to have this done professionally please?
Hi, I need to remove some radiators for redecorating and went to try and shut off the valves either side of my rad. I have TRV on one side and on the other side I noticed a blank top with no valve or peg sticking out that allows you to turn on or off (see pictures). I checked the other rads in...
Hi All, I need to replace a radiator in the kitchen, the 10mm copper has split so using this opertunaty to replace it with a towel one and also need to remove both valves and make the pipes shorter. Its a gravity fed system and the last radiator in the system , I have a bung kit, i know i can...
